Thread: cabin leak
Old 09-29-2004, 10:52 AM   #22
Shortbus
Shortbus's Avatar
Send a message via AIM to Shortbus Send a message via MSN to Shortbus Send a message via Yahoo to Shortbus
so how do you guys check the entire drain for blockages? Do you run some sort of wire through it???? In my case, I keep getting water in my driver side door around the speaker, which i think leaks onto the carpet on the driver side floor. The dealer wants 400 bucks to replace my door seal. Screw them.
If I drop water onto the windsheild on the driver side, i see water coming out from under the driver side door. Is this normal? Looks like it's draining water into the door jamb.
Shortbus is offline   Reply With Quote
