Old 04-12-2007, 04:11 PM   #13
z12358
You're complicating things too much. If the market is telling you that both choices are priced similarly, then that's your answer in terms of generally perceived value. You won't get much more than that from this forum. You need to do some testing and answering work on your own to make your own PERSONAL decision that will reflect your PERSONAL preferences. Go to a dealer that has an 986S in inventory, and test drive it with the 987 back to back. See if the new 987 interior catches your eye. See if the kick from the 986S 3.2 liters matters to you more than the less fancy interior. Take your time, look at different color combos of both cars and let it sink in. Then follow your heart and pull the trigger. You can't do wrong.
Z.
'06 Boxster S, 6sp, triple-black
http://i153.photobucket.com/albums/s...05_IMGcrop.jpg
z12358 is offline   Reply With Quote
