Old 04-10-2007, 11:34 AM   #1
CJ_Boxster
Send a message via MSN to CJ_Boxster
5 speed Tranny grinds
I need some insite as to what the issue is that im having with my boxster, Its a 97 boxster 5 speed with 108k miles....
Issue im having is that i hear a grind noise ONLY when im changing from 1st into 2nd gear while making a left or right turn. I make the gear change in the 3500 - 4000rpm range and as the shifter is entering 2nd gear, i hear the grind. Again, this ONLY grinds while going into 2nd gear while turning!
In Addition: The only way the tranny wont grind while shifting into 2nd during a turn is if i wait for the RPM's to drop to idle before shifting into 2nd.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
