Its not cheap...but it's not the brightest of ideas......
you can get your top replaced because you had a reasonable problem...the tow truck guy scratched.
the only way you can get a new bumper is if the tow truck guy scratched it....
why in the world did you not take the new top....you should of set up a date when you were available. you obviously werent much concered with the scratches....
you're out of luck now...not even sure if they will replace the top now!
