Old 04-08-2007, 03:06 PM   #1
c-c
Consumer Guide Report - Issues / Resolutions
Thought posting this guide may be helpful to some:
Trouble Spots
Consumer Guide's® Auto Editors have scoured repair bulletins and questioned mechanics to search for commonly occurring problems for a particular vehicle. In some cases we also give possible manufacturer-suggested solutions. In many instances these trouble spots are Technical Service Bulletins posted by the manufacturer, however, we have our own expert looking at additional vehicle problems.
Check-engine light: Leak in oil filler hose between crankcase and service unit might cause check-engine light and engine roughness. (1997-2000)
Dashboard lights: The check-engine light may come on due to a loose gas cap or damaged gas-cap seal. (1998-99)
Engine misfire: An engine miss might be caused by water in the air-cleaner housing. A water-separator bowl must be installed in the housing intake. (1997)
Oil leak: A steel plug in the cylinder head may cause an oil leak. An aluminum plug is available to correct the problem. (1997)
Vehicle noise: On cars with a manual transmission, the power-steering-pump belt may squeal during parking maneuvers. Replacing the original aluminum pulley with a steel pulley eliminates the noise. (1997-98)
Vehicle shake: If the hardtop rattles, replacing the centering-pin caps with redesigned caps might correct the problem. (1997)
Consumer Guide® Estimated Repair Costs
This table lists costs of likely repairs for comparison with other vehicles. The dollar amount includes the cost of the part(s) and labor (based on $50 per hour) for the typical repair without extras or add-ons. Like the pricing information, replacement costs can vary widely depending on region. Expect charges at a new-car dealership to be slightly higher.
Item Name Repair Cost
A/C Compressor $760
Alternator $430
Automatic Transmission or Transaxle $1,460
Brakes $745
Clutch, Pressure Plate, Bearing $765
Constant Velocity Joints $2,150
Exhaust System $870
Radiator $890
Shocks and/or Struts $1,600
Timing Chain or Belt $850
NHTSA Recall History
1997-98: Contact buckle supplied with child-seating system airbag-deactivation kit does not deactivate the airbag.
c-c is offline   Reply With Quote
