Old 04-04-2007, 08:55 AM   #1
denverpete
Loose connections are always a possibility, particularly if any of the wires are tapped.
If none of those suggestions work: It could be a faulty ignitor, the ballast assembly was placed too far away from the lamps, incorrectly wired ballast/ignitoror, incorrect (reversed) wiring to the lamp, or the lamps are failing. Each of these tends to produce the flickering you are talking about.
'06 Cayenne Turbo S, Beige Metallic/Tan
Ex - '99 Arctic Silver, Red Interior, Silver Top
denverpete is offline   Reply With Quote
