Litronic Headlight FLICKER? Intermittent at Startup?
Hey guys, I installed a new pair of Litronics a few weeks ago, and the first time I turned them on, the lights just flickered as if there wasn't enough power going to them or something. Then turned the switch to off, and the 2nd time, they worked perfectly.
I notice this happens almost every time I turn them on, maybe 9/10 times. And will work perfectly normal the 2nd switch-on attempt.
Today, I turned on the headlight switch, and it would flicker and not fully ignite, and then kept on doing that on subsequent attemps. After giving up for awhile, I came back and tried again and they fired right up perfectly.
(both sides always work in unison, whether it be both doing the flickering, or both operating normally, so I don't think it has to do with a connection/plug issue on a particular side).
Any ideas on what the culprit might be? Maybe headlight switch connector?
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
