Old 03-27-2007, 03:23 PM   #16
FrayAdjacent
Well, if you get just the little LCD/button panel part of it, it's still easy to get at. You take out the whole assembly as I pointed out, then there are four screws holding the face plate to the white plastic housing. Unscrew those, and the face plate is loose. There's a small ribbon cable connecting the faceplate to a PCB in the housing. Disconnect that, plug in the new face plate, screw it on, and reinstall the whole unit. Probably still a VERY quick job.
And CJ, yeah, the PO apparently trusted that cupholder a little too much... Everything had coke residue in it in that lower console.
Originally Posted by butterfingers
Thanks for your comments FrayAdjacent!
I am really hoping that its as simple as you say it is for the LCD replacement. What got me doubtful was an earlier post in the message tread that stated that someone had tried to replace the LCD with a similar kit that I bought, and though the replacement seemed easy enough, after the 'surgery', their instrument cluster did not work....
I mean, for the price, if it works, it would be a fantastic self repair that could save hundreds of $s to avoid replacing the whole climate control unit just because of the LCD damage.
Fingers still crossed till I get the kit in my hands and try to do the replacement!
2001 Boxster - Grey on Grey
1969 911T Targa - 'Stinky'
http://www.zoto.com/frayadjacent/img...f27a-4a399.jpg <---- my car. ^ crap I post.
"The existence of the flamethrower is evidence that someone, somewhere once said 'I want to set those people over there on fire, but I don't want to have to walk over there to do it.'"
FrayAdjacent is offline   Reply With Quote
