				Found!- Switched 12V Spare Fuse in 987
			Just reposting this as it was buried in another tread I started about radar detectors that some folks could care less about but this could be useful.  After some voltmeter work I finally found a switched 12 V connection suitable for my radar detector.  It's not a V1 or Escort that has the RJ-11 4w connection.  I just needed a 2 wire 12V and ground connection for my BEL 985 Vector.  Hot to the fuse slot, ground to a nearby chassis ground lug.
 Fuse box ROW D, FUSE SLOT #4 is empty on my 987 and will provide 12V only when switched on by the key. This is shown as a blank in the little book so I imagine that regardless of the options on your car, this looks to always be a spare empty port that is only hot when the key is on.
