It is called a pal nut. But I have always called it a speed nut.
Need an 8 mm socket. 1/4" drive so it can fit in the hole. If you use 3/8" drive then you need a deep socket.
If your socket engages the nut but it just spins then report back.
Or, I could sent Larry over....
