Old 03-21-2007, 04:38 PM   #3
husker boxster
husker boxster's Avatar
If no one else has a better way to ID it without digging out tools, you can always remove 2 bolts and look at the rear panel of the amp. It will say 4x60 or 6x60. The first number indicates the number of channels. If you have a 4 chl, the rear spkrs are running from the radio. You will need to look at your amp anyway if you find you are a 4 chl and want to upgrade to a 6. There are 3 versions of amps (Bose, Harman, Haes) that could be used and you want to be sure to get the same version that's already in your Box. You can read the version without having to remove bolts (just can't see the # of chls). The amp is located between the spare tire and battery cover in the front compartment.
1989 928 S4 5 spd - black
