Peter: Gauge face replacement will not change your mileage on your Boxster if you use the same cluster and don't drive the car without the cluster plugged in.
I've never changed the faces, but I had my cluster replaced and thought of doing it myself but it needed dealer programming so I had them do it.
ToolPants does it all the time though and says it's just two screws (small speaker cover on left, an one screw behind the emergency flasher on the right) to get the cluster off the dash.
I have my old cluster in the garage and I just might tear it down to see how one can change the gauges out. I know renntech.org has some pictorial posts on how to do it.
Chris: How much are you planning to charge for these replacement faces?
