Old 03-17-2007, 11:17 PM   #3
blinkwatt
Send a message via AIM to blinkwatt
Originally Posted by aussieboxy
Hi,
It's my 1st time workin on the Boxster. I had a bit of a look but was unable to see the throttle body. Do I need to take off the black induction pipes to get access to it. I got a Mitchells manual on CD and it's absolutely useless
Thanks for your help
The black induction pipes(intake system) should lead up to a shiny metal thing,that's the throttle body. You should only have to loosen up the intake tubing to get the throttle body out. Before you do that and take a couple hours I would suggest just smoke testing which takes only a couple of minutes, if there is a leak then you saved a bunch of time.
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
