Mine does this and it seems perfectly normal to me. When you first pull the door handle the window drops slightly to clear the track. By opening quickly, you aren't giving the mechanism a chance to complete and the window drags as you open the door.
I don't think this is an indication of a problem with the car...just your technique.
If, however, the window clips after it has dropped all the way, then that would be an indication of a problem.
