Old 03-15-2007, 09:59 AM   #10
CJ_Boxster
Send a message via MSN to CJ_Boxster
I have what i call the Pin Ball Machine protection method... a Walther P22 LR, its a .22 caliber handgun. Very reliable, low recoil, highly accurate and pretty good looking to boot. I call it Pin Ball cause if one of these rounds makes it through the rib cage, it will likely bounce off another rib or the spine from the inside and change direction... Its like being shot once from the outside and then 2 or 3 more times from the inside.
Here's what she looks like, cost me only $360 after taxes and fees.
I have the 3.4 inch barrel version but upgrade to the 5inch cost about 90 bucks however the compensator is non-function but supplies you with more accurate shots as well as counter weight and more balanced feel.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
