Are you sure it is not hiding under there?
This is the only dectent picture I have of the area. The picture was taken for another reason - not to show the routing of the vent tube. I have put yellow lines next to the tube. I also have an aftermerket battery and use the black rubber adapter tube.
It is just clear plastic tubing that you can buy at a hardware store.
It goes down in the fender area. I would have to look at 8 years of pictures to see if I have one that shows where it daylights. I remember a guy who raced his car relocated the tube because he said it was dripping acid on something.
I just cannot believe someone would yank it out.
Would like to know how the PO got that changer to work since youe 2004 is a MOST car and the only changer I know that will work with a MOST car is the CDC-4. What is the model number?
