I'm thinking of getting some new rotors, and was going to get the cross drilled and slotted ones, but since you say all that stuff, would it be better to just get slotted? I know that you should use a "slotted" pad with regular rotors for the gas escape, and a "solid" pad with drilled rotors because you dont need the slot in the pads anymore, so what im asking is, are slotted rotors ok, as long as they arnt drilled?
