If you backed out a bolt 1/4" and then the rest of the bolt did not back out easily....
Then it will not move with an 18" breaker bar. You can get it out with a 18" breaker bar but you are afraid to pull harder because something is going to get screwed up, like the threads. But they already are.
Not good.
As I said, I see this on the UK Boxster boards because of the stuff on the roads. By the time they finally get the bolt out the aluminum threads are stripped. If they are lucky they can use a thread chaser to clean up the threads and still hold 63 pounds with a new bolt. If they are unlucky then time for another caliper. I don't know if you can heli-coil it.
I do not know why you want to remove the caliper - painting them - rotor replacement. If there is no very good reason to get the bolts out then tighten up the one and let the next owner deal with it. My free advice of the day.
