Originally Posted by MNBoxster
Hi,
Try turning the bolt back in and use a wire brush to clean the exposed threads. Then try some PB Blaster (an enzyme containing penetrant which will literally eat rust and salt). If that doesn't work, try some heat, carefully applied to loosen things up...
Happy Motoring!... Jim'99
Ditto, ditto ditto. I would continually and liberally douse with PB Blaster. Do this over the course of a couple hours. Seriously. Let the stuff work. If that doesn't work, get yourself a small MAPP gas torch from Sears. Work carefully. Do not burn rubber caliper boots, brake lines, or ball joint boots.
