Thread: Brake Pads
Old 03-12-2007, 11:15 AM   #2
FrayAdjacent
- when the Brake Wear light comes on on the dash.
Anyway, my Box had 40k miles on it when I got it, and the pads were almost on the wear sensors. About $110 and two hours of my time, and I had them swapped. The rotors should be fine, but next time I have to replace pads, I will go ahead and replace the rotors.
If you want to gauge your rotors, here's the specs:
Front rotors 24mm new 22mm worn
Rear rotors 20mm new 18mm worn
Basically, if your front rotor is less than 22mm, you'd need to replace it. 18mm for the rear.
2001 Boxster - Grey on Grey
1969 911T Targa - 'Stinky'
http://www.zoto.com/frayadjacent/img...f27a-4a399.jpg <---- my car. ^ crap I post.
"The existence of the flamethrower is evidence that someone, somewhere once said 'I want to set those people over there on fire, but I don't want to have to walk over there to do it.'"
FrayAdjacent is offline   Reply With Quote
