Old 03-11-2007, 01:36 PM   #1
Boxtaboy
07 Carrera S Cab
Boxtaboy's Avatar
If your car is newer than an 01, you already have the updated grill that blinkwatt is talking about that has the 2 bottom louvres with the vents blocked off. This updated louvre, btw, is only of use if you keep the snork w/ the cup at the end inserted, as it brings the level of the airflow up to the level of the cup. If you take out the snorkel, it's better to have the old louvre style, as it allows less air to flow through due to the blocked off lower louvres.
If you really want an updated vent style, buy the 03+ one piece intake vents that need to be painted body color. They fit without issues to the older 986 intake assemblies.
