Old 03-08-2007, 10:01 AM   #4
FrayAdjacent
PB Blaster is your friend. If you can't loosen the nuts or screws, hit it with some PB Blaster and give it a few minutes.
Simple tools should get you done. It's relatively easy to remove the calipers and rotors.
I'd also recommend getting some rubber gloves. The blue ones... the regular yellowish/clear ones are pretty thin, the blue ones are tougher. I recommend this because after changing my brake pads, I had black gunk under my nails for a couple weeks! Makes clean up a lot easier if you use gloves!
2001 Boxster - Grey on Grey
1969 911T Targa - 'Stinky'
http://www.zoto.com/frayadjacent/img...f27a-4a399.jpg <---- my car. ^ crap I post.
"The existence of the flamethrower is evidence that someone, somewhere once said 'I want to set those people over there on fire, but I don't want to have to walk over there to do it.'"
FrayAdjacent is offline   Reply With Quote
