Old 03-08-2007, 09:07 AM   #1
CJ_Boxster
Send a message via MSN to CJ_Boxster
The screws on the front rotors can be done by hand. The rear rotors will be alittle more stuck, Place a screw driver on then, then give the back of the screwdriver afew good taps on the head with a hammer or heavy wrench... that should make it easier to brake free. You dont need new sensors if you dont have a "Brake Wear" warning light on your dash that is solidly lit while your driving., you can re-use the old ones.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
