Other than a Brake dust Cleaner spray, jack, jackstands, and the lug nut wrench... YOu need a large Allen key to remove the 2 bolts holding the caliper to the hub... not a 10mm socket or wrench, Its a Allen bolt. Then 2 phillips screws holding each rotor to the hub. Might need a pick to pop the brake wear sensors... careful they crack and crack kills!
