Old 03-08-2007, 09:06 AM   #2
CJ_Boxster
Send a message via MSN to CJ_Boxster
Other than a Brake dust Cleaner spray, jack, jackstands, and the lug nut wrench... YOu need a large Allen key to remove the 2 bolts holding the caliper to the hub... not a 10mm socket or wrench, Its a Allen bolt. Then 2 phillips screws holding each rotor to the hub. Might need a pick to pop the brake wear sensors... careful they crack and crack kills!
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
