Thread: tire cupping
Old 03-06-2007, 06:37 PM   #4
Houston C4S
It's good to catch this sort of thing early.
Absent tire imbalance and worn suspension
parts (which you should notice while driving
it) I would suspect alignment.
MNBoxster gave you some great pointers.
I think I should point out however that in this
statement:
"But, be sure to do these adjustments/checks before
installing a new set of fre$h rubber. Hope this helps..."
MN, I am sure, meant for you to check everything,
get new tires and then get it aligned.
Tires that are worn and cupped will cause different
alignment settings than your new ones. Always
align with the new tires in place.
I am sure that's what he meant to say.
All the best,
- Mark
Houston C4S is offline   Reply With Quote
