Originally Posted by 986speedster
I dont think its turning at all. Did you have to push the tool in forcefully? (I know, it sounds bad) So you turned it towards the front of the car? I read in the PCA.org tech site, to turn it towards the back until you hear a click. There are three openings per light, correct?
I was guessing on the first position as to turn. If it says towards the back, then that is probably right. It should make a click or poping sound when it dis-conects. There is only 1 hole for the tool to go in per side. Not 3 per side. Make sure the tool is in place and in the socket. It should not be loose before you turn it.
