Originally Posted by cpiuma
Thank you both for your prompt response and assistance! The tires are a soft summer variety, type: Continental Sport Contact 2's. They haven't been rotated and appear to be on the correct sides. There still is quite a bit of central tread, with the side tread somewhat worn towards the very outer edge of the sidewall.
One thing to note... those tires have been unmounted and swapped to the other side. The Boxster wears out the INNER edge of the tire, not the outer edge as you described. Some people have the tires unmounted and swapped to the other side so the rotation is still correct, but now the inner edge is one the outside. Gives you a bit more tire life.
On the other hand, I just put new BF Goodrich Geforce tires on mine, and I still have what I thought was tire noise coming from the rear. I may have wheel bearing starting to go as well. I'll wait until I get my lift if they have to be changed.
