Old 03-05-2007, 07:50 PM   #6
MNBoxster
Originally Posted by mswab
one more time. What most people do is start the engine and take a can of R134a, with correct hose and valve see NAPA or Autozone, and spray the 134a on and around the intake system. Once you hit the leak the idle will drop as R134a is a really great fire extinguisher. You can use propane to do the opposite, the idle goes up, but the risk of explosion has always turned me off to this method.
Hi,
That is not a good, or environmentally sound idea. R-134a (or 1,1,1,2-Tetrafluoroethane) while not ozone depleting, isn't really good stuff to Free-Vent either.
1,1,1,2-Tetrafluoroethane is slowly converted to trifluoroacetic acid through a radical reaction in the upper atmosphere and leads to a detectable amount of several ng/L rain.
Contact of tetrafluoroethane with flames or hot surfaces in excess of 250°C (482°F) - well within the temps of a hot engine, can cause vapor decomposition and the emission of toxic gases including hydrogen fluoride and carbonyl halides. Its gaseous form is denser than air, and will displace air in the lungs. This can result in asphyxiation if excessively inhaled.
Under pressure, tetrafluoroethane is compressed into a liquid, which upon vaporization absorbs a significant amount of thermal energy. As a result, it will greatly lower the temperature of any object with which it comes into contact as it evaporates. This can result in frostbite if it comes into contact with skin.
According to the MSDS, "In a two-year inhalation study, HFC-134a at a concentration of 50,000 ppm, produced an increase in late-occurring benign testicular tumors, testicular hyperplasia and testicular weight." - Sources: Honeywell International (December 2005). "MSDS # GTRN-0047 For GenetronŽ 134aUV".
Alexander D. J, Libretto S. E. (1995). "An overview of the toxicology of HFA-134a (1,1,1,2-tetrafluoroethane)". Hum. Exp. Toxicol. 14: 715-20.
There's really no need for this fancy stuff. An atomizer (Spray Bottle) filled with plain water will accomplish the same thing. Add a little Glycerin or Soap and watch for bubbles...
Happy Motoring!... Jim'99
