Hi,
The headlights have vapor drains in them which draw off any built up vapor through Bernoulli action of air passing past the drain tube under the car. But, if the car isn't moving, this isn't possible, which is what I suspect is the case with you.
You could also check to see that the drain tube isn't plugged. Hope this helps...
Happy Motoring!... Jim'99
