Thread: Engine Temp
Old 03-04-2007, 09:22 PM   #1
MNBoxster
Originally Posted by David N.
If you really wondering, there's a hack for the A/C display to show real-time sensor data. You can read the coolant temperature from there and know an exact number. I think 110 degrees C is probably about as high as you would expect it to go normally, low-mid 90s when at speed in cool air (that's been my experience at least). Anyone know the thread where it lists all the codes and how to access them?
-David
Hi,
It's not a hack, it's putting the Audi-sourced Climatronic into it's diagnostic mode. Only works through '00 MY. There are 35 different parameters which can be displayed such as cabin temp, coolant temp, oil temp, Fan RPM, Trus speed (in KPH), etc. Hope this helps...
Happy Motoring!... Jim'99
