Old 03-04-2007, 06:37 PM   #10
glenn986
Originally Posted by Tool Pants
You can guess all day long until you have the head pulled.
Most common is a cracked cylinder, head, or gasket.
Joe's 996.
Hey Tool,
I have both heads removed, but their integrity is in-tact. It is certainly not a cracked cylinder either. Right now, I'm in the process of testing the crankcase.
The image you show is quite catistrophic! This sort of failure could easily be located before engine removal by a compression test -not to mention the huge amounts of coolant entering into the one particular cylinder.
cheers,
glenn
glenn986 is offline   Reply With Quote
