$2
Did my IPOD enhancement for only $2. Went to big lots and bought a cable phono to RCA cable.
Cut the RCA cable ends off. Joined the copper ground wires together and was left with 3 wires. Red, Copper, White. Cut some wire connectors in half to fit the small connections on the back of the 220. Put them on the old RCA ends of the cable and pressed them on the back of the sterio. Voila works great. I connected them to the three far right connections on the sterio. Top white, middle (Below) ground and bottom is Red.
Press and hold your TP button to get serial number etc... go to aux and turn it to "ON".
Now when you want to listen to your ipod just press "S" source and go to AUX. Works great!
