Wow Travis thanks for all that info... soooo:
Hold down button for 5 seconds (also look to see if alarm dash light flashes)
Alarm dash light does flash. Nothing else happened.
If trunk does not open and alarm light flashes, manually open trunk and press again to see if the latch/actuator "pops"
Latch does not pop =(
If latch does not activate with lid open verify your spoiler works (both use same fuse - D9 I think) Press manual switch for spoiler on fuse box
Spoiler works.
If spoiler works then fuse is good, if not replace fuse.
Yay fuse works.
If spoiler/fuse is good, pull out the rear portion of trunk liner next to latch and look towards the left and down of the latch you will see a plastic connector with two connections (single wire is for trunk, double is for spoiler) verify that they are connected.
This is where it gets confusing... I took the trunk liner out by unscrewing the latch guard thingy and pulling out 4 plastic screw things that hold down the felt liner. On the bottom left I did see a clear plastic connector with a blue and red wire. And further down I saw two brown wires connected to two brown wires... But yes the connectors are all connected.
