I have the mesh inserts, but they rattle against the metal rollbar. The inserts are hard plastic with three integral clips. Each clip has a soft "rubber" pad which, I suppose, is to isolate the plastic from coming into contact with the metal rollbar. Some of these "rubber" pads have moved, but not enough I thought to cause the rattle.
Does anyone else have this problem and how did you fix it?
