Old 02-25-2007, 12:11 PM   #1
RandallNeighbour
If the cables are the newer ones with a diamond pattern embedded in the plastic sheath surrounding the cable (which is reinforcement) you're probably good for a long time cable-wise.
Heat issues stretched the first batch on 97-99 models. The cable inside is made of steel and doesn't stretch, but the outer sheath did and that caused it to stretch and disengage from the motor or transmission and caused all sorts of $$$$ problems.
Not a bad idea to have them inspected though... they're not expensive, but if they are removed, re-timing the top may cost you some extra money.
