That's right... the clutch is a wear item like the brakes and tires.
Man, that's not many miles for a clutch if it is indeed the problem! If the dealer tells you that's what it is, consider telling them to give you the car back without replacing it.
Then buy the parts from Sunset and get a reputable independent mechanic to put it in. This will not void your warranty, but it may save you as much as a grand.
The problem is that on our cars, they have to drop the tranny to change the clutch. It's 8+ hours on the repair.
