Old 02-24-2007, 02:01 AM   #2
wpruitt
Will Have Clear Headlights For Sale
I am going to have a set of clear headlights from a 2003, including the clear reflector triangles for sale next week. No scratches, no broken mounts and will include a complete HID kit as well. Replaced with Litronics and will be shipped in the box that they came in.
I did the retrofit to HID but the kit kept causing an error with the battery idiot light. I removed them but have since received a battery direct kit from the manufacturer which should eliminate the problem I was having. The rear of the headlights access panel has been drilled and a grommet installed to allow the wiring for the HID kit. I have since applied silicone to the wire holes on the grommets to seal it up. It is fine as- is or you could replace it with the one on your existing headlights. I have two extra grommets if you want to use the HID kit. I was planning to ask $600 plus shipping.
PM me if interested.
Warren
wpruitt is offline   Reply With Quote
