Be prepared...
I had the same thing happen to mine... turned out it was the line from the Master cylinder to the Slave cylinder. Parts and labor with bleeding the system and new fluid was almost 800.00 at my local dealer.
Dont let them talk you into replacing the brass fittings at the ends of the line if this is indeed what it is. You dont need them and they are over 100.00 each.
Best of luck!
Joe DiMonte
2001 Boxster S
Triple Black
