Old 02-23-2007, 02:45 PM   #1
ehD
Do you have a leak?
At the time I'm not sure, it was pouring heavy rain. The day after I had it towed there was no sign of leaks.
Is the underside of your car wet or sprayed with hydraulic fluid?
Honestly I don't know what hydraulic fluid is but yes, it was very wet from the rain.
Can you put the car in gear?
Yes I can shift between all the gears.
With the engine On? Off?
Yes and yes.
What's the fluid level in the Hydraulic Fluid Reservoir in the front trunk?
Hrmm I'm not sure I don't have the car with me right now...
At or Below the FULL line? If below, by how much?
Ditto...
Personally, I don't think you have a burst Hydraulic line. From your description so far, I'd say that something mechanical broke in the clutch itself, or you have a failed Master Cylinder. But, I'm not certain of anything since your description is so lacking. Give us more information please...
The clutch seems fine.. it seems like its the pedal? I could be completely wrong... Are these repairs going to cost an arm and a leg? I just got this car 3 days ago and I have a feeling I'll be in a world of pain in terms of repair costs soon =(
ehD is offline   Reply With Quote
