Thread: Need top advice
Old 02-23-2007, 08:42 AM   #19
jmabasa
Originally Posted by Chills
Okay, so here's what I did:
My fiance found some plastic/vinyl glue at Lowe's made by Loc-tite, and I glued the window together. Now before you start flaming poor Chills let me explain.
The crack is about 4 inches long and right along the fabric. I took a toothpick and used it to apply small amounts of glue along the inside of the crack and then put a small layer on top of the crack. I did two applications just to make sure, letting it dry and set a day between applications.
Amazingly enough it worked. The glue is holding. I washed the car on Tuesday and the crack didn't leak. It was so nice later that day that I put the top down, and the glue held. It didn't crack.
From the outside you can't see it unless you are looking for it, so it doesn't look trashy at all. Now mind you, this is a temporary fix. I will still get a new top with a glass window, but for now I can still drive around and not worry about the crack.
Thanks for the info! At least now we know that there's a temporary fix that won't stick out like a sore thumb.
2001 Lapis Blue Boxster
http://i123.photobucket.com/albums/o...asa/ebcomp.jpg
jmabasa is offline   Reply With Quote
