Good chance that the line has a hole in it and you lost fluid. I had the same problem when a rock or possibly someone improperly jacked the car up and fractured the clutch line. The line is aluminum with a blue plastic type coating on it. Replaced mine in my garage for $63.00 plus fluid. Its a pretty simple fix in my opinion.
I just read your post again and I may have misunderstood. So you can change gears while its running and if the clutch would release you think the car would move?
2002 TT
