Old 02-23-2007, 04:31 AM   #1
ohioboxster
ohioboxster's Avatar
Good chance that the line has a hole in it and you lost fluid. I had the same problem when a rock or possibly someone improperly jacked the car up and fractured the clutch line. The line is aluminum with a blue plastic type coating on it. Replaced mine in my garage for $63.00 plus fluid. Its a pretty simple fix in my opinion.
I just read your post again and I may have misunderstood. So you can change gears while its running and if the clutch would release you think the car would move?
2002 TT
ohioboxster is offline   Reply With Quote
