Thread: Engine Temp
Old 02-22-2007, 03:16 PM   #2
MNBoxster
Originally Posted by racer_d
180 "ish" is fine. The actual number is likely closer to 190. This question has been asked before and the consensus is the same. It will fluctuate with type of use (stop and go in 85 degrees with the AC on it will run hotter than 45 degrees at freeway speeds)
Hi,
+1 - your engine does not always (perhaps even rarely) operate at the exact same temperature. Load, Ambient Temperature, Barometric Pressure, Humidity, Fuel Octane, DME Maps, Avg. RPM, even Wind speed and direction can all, or in combination, affect what the gauge reads. So, don't obsess about a static number, but as racer_d suggests, look for a range...
Happy Motoring!... Jim'99
