Old 02-22-2007, 09:12 AM   #11
Bisimoto
Send a message via AIM to Bisimoto
Originally Posted by porsche986spyder
I wonder if the shape of the snorkle tube being a long smooth part leading up to the intake had some type of airflow/aerodynamics pupose. Therefore it would have been better to test it on the dyno with a fan blowing on the intake vent to simulate the car moving forward, since it was sitting still when you did the before and after test. Just a thought to consider for future testing.
I did use a fan in 2 areas: the front for the heat exhanger/radiator, and the rear driver's side vent, but only to provide cool air. A single cylinder in our P-car engines demands air at 2000RPMs that none of my industrial grade fans can generate. As a matter of fact, a NACA duct (superior to our Porsche side vents) is only efficient as a ram at above 200mph.
2 weeks ago i performed a test using a fully radiused intake pipe on single cylinder induction tubes, and gained 12whp on a 320whp engine. Infusing such technology in our induction may prove benefitial, but the factory ram tube, incorporated with the "deflection cup" is a restriction, and hence, the power gains seen in the upper RPM range.
Thanks for the suggestion...great minds think alike!
Bisimoto Engineering
2001 modified Boxster S, slate grey, red interior
Bisimoto is offline   Reply With Quote
