Old 02-21-2007, 09:29 PM   #2
Cloudsurfer
Right now dealers are quoting around $1800, cheapest you'll see officially is about $1400 and if you look hard you may see $1200. This is for the full kit, brand new.
Its worth noting, that the full kit enables the low beams to be moveable to match the high beams (tipping them up a few degrees when the highs are engaged). You will not get self leveling when retrofitting. You can also just plug in the litronics and not bother with the tilting function the control module adds.
Its always nice to save money and pick up Litronics used, but keep in mind if you get a used set and have to replace an HID capsule, the savings just got eaten up.
I would absolutely stay away from doing an "HID conversioin kit" into the factory reflector housings. Beam pattern will be horrible.
Tails and side markets are an easy bolt in replacement, so I'd just look around and find the best deal you can for those.
Patrick
