Old 02-21-2007, 11:01 AM   #13
Travis
Send a message via AIM to Travis
It is a tight fit, but I moved the seat all the way down and back, then sat reverse in the seat and lean backwards so my head and shoulders were under the dash.
Removed (just pulled apart) the air duct and reached up to the right to the switch to unscrew, you can see the left-hand screw and will have to feel for the right hand screw (they are recessed a bit so not to hard).
I used a eyeglass screwdriver to remove, I also ordered two and keep an extra with screwdriver in my console just in case I get caught away from the house like last time.
Originally Posted by porschedude
I crawled underneath the dash and everything was so tight. I could not even get to the red screws close to the right. I lied down flat on the floor mat too. So please let me know how you did it? Also, did you use a mini screwdriver? Thanks!
Travis is offline   Reply With Quote
