You're forgiven
I have had the same issue with the ignition switch, starts off feeling just like you mention below but gets worse as time goes on.
- Key will get stuck and must wiggle (the key) to remove
- when key removed radio & inside lights stay on
- AC will start acting up
- key will end up not being able to start car or even insert into ignition.
I replaced the plastic switch assembly and it has worked fine for 8 months, but i thought there was a TSB with this and the fix was to replace the entire ignition switch assembly. (took me 5 minutes and cost about $25.00)
Originally Posted by C5150
Forgive me for any ignorance on my part - but are you sure the key not turning is not caused by the steeringwheel lock - released by turning the wheel a bit? (generally caused in my experience by not setting the e-brake before letting off the brake)
