Old 02-21-2007, 04:19 AM   #3
Travis
Send a message via AIM to Travis
You're forgiven
I have had the same issue with the ignition switch, starts off feeling just like you mention below but gets worse as time goes on.
  • Key will get stuck and must wiggle (the key) to remove
  • when key removed radio & inside lights stay on
  • AC will start acting up
  • key will end up not being able to start car or even insert into ignition.
I replaced the plastic switch assembly and it has worked fine for 8 months, but i thought there was a TSB with this and the fix was to replace the entire ignition switch assembly. (took me 5 minutes and cost about $25.00)
Originally Posted by C5150
Forgive me for any ignorance on my part - but are you sure the key not turning is not caused by the steeringwheel lock - released by turning the wheel a bit? (generally caused in my experience by not setting the e-brake before letting off the brake)
Travis is offline   Reply With Quote
