Old 08-27-2004, 08:25 AM   #4
mrmickeymouse
You should not supercharge a High Comp. motor.
If you wanted to do it without doing [less] damage to your motor.
The best methodology would be to drop the compression, add a better oil pump.
Then cross your fingers for reliability.
If you want longevity do would Ad Sach said, that is the reliable way.
mrmickeymouse is offline   Reply With Quote
